Community Member
Load Balancing acrros two T1s
I have two point-to-point T1 circuits running from my campus to a remote office. On the remote sight router I have a single broadcast domain, and I run NAT on the Ethernet interface of a 3640, with two serial ports serving the T1 circuits. On campus the T1s are terminated on a 4700, that connects to my backbone. I want to load balance incoming and outgoing trafic across these two T1 circuits. How can I accomplish this?
Community Member
Re: Load Balancing acrros two T1s
Depending on the latency; if the latency is low run OSPF maxipath=2 or multilink ppp.
Community Member
What routing protocol are you running? Some protocols load balancing up to 4 path by default. Do a trace to your remote site and you will see what I mean.
Community Member
Also, what type of load balancing are you wanting to achieve... for 50/50 split of traffic, you can use cisco express forwarding (CEF) with per packet balancing activated on each T1 interface.
113
