10-08-2003 08:45 AM - edited 03-02-2019 10:52 AM
I need to bridge two WAN sites. It was determined that one T1 is not enough and DS3 is too much. So we are looking at two point-to-point T1s. Lets say I buy two 2621XM with build in DSU/CSU (WIC-1DSU-T1). How do I go about implementing bridging and load balancing? Do I just make all interfaces (FE0, S0/0, S0/1) on both sides members of one bridge group? How would load balancing be handled in this case?
Thank you in advance
10-08-2003 11:30 AM
You can use Multilink PPP.
check the following link for more detail:
Bessie
10-08-2003 01:45 PM
This is what I would use if I am to route on serial interfaces. Do you know how it works with bridging? I was not able to found this info so far.
10-08-2003 11:42 AM
I have not tested this, but putting all interfaces in the same bridge group and then assigning the same path cost (bridge 1 path-cost xxxx in interface configuration mode) might work.
Georg
