load balancing between routes learned via different routing-protocols
Hi I am looking for a possibility to get two routes which are learned by different
routing-processes (for example two ospf processes) into the routing-table to load-balance between the two routes
I setted the administative distance for both routing-processes to the same value, but I could only bring one of them to the routing table, though the have the same distance and same metric
any idea about a workarround ??
1 REPLY
Re: load balancing between routes learned via different routing-
Although it seems to be logical, Implementation wise this might be a limitation maybe a developer can comment more on this.
97
