Load balancing help
Hi, all,
I understand that CEF only load-balanc known networks because CEF depends on routing table.
Then how does CEF load-balance unknown networks or does CEF load-balance unknown networks at all?
If not, how do I load-balance unknown networks? Create two default routes for each T1 we are running? Thanks,
1 ACCEPTED SOLUTION
Bronze
Re: Load balancing help
CEF load balances over default routes just like it does over other routes.
1 REPLY
Bronze
88
