Load Balancing HSRP
I have a remote site with 2 routers connected to 2 seperate Frame Relay clouds. HSRP is setup for remote site router failure. I would like to load balance my users across both of these Frame Relay links instead of using one link only. What are my options for load balancing HSRP across two routers in an HSRP group?
1 REPLY
Silver
Re: Load Balancing HSRP
Please see http://www.cisco.com/univercd/cc/td/doc/cisintwk/ics/cs009.htm
HSRP priority is commonly used for this.
Keep in mind that true load balaning in this environment is both to and from your remote site. Proper setup of a dynamic routing protocol can help achieve this as well.
Hope this helps,
Don
91
