load balancing more than 6 paths
If RIP has 8 paths to the destination that have the same cost, it will choose 6 as the maximum number for load balance (assuming that RIP is configured for load balance among 6 paths and not 4).
How will it choose these 6 paths? Because when it chooses 6 paths, it has to ignore/drop 2 paths.
Please clarify.....
Thanks in advance!
1 REPLY
Re: load balancing more than 6 paths
It is actually CEF that is selecting which paths not RIP, as RIP will put all 8 paths in the RIB. It is then up to CEF to put those routes in the FIB based on its determination which paths to select.
Check this link out
http://www.cisco.com/en/US/products/hw/modules/ps2033/prod_technical_reference09186a00800afeb7.html
-bryan
98
