Load Balancing on two dynamic ADSL Connection
Hi All,
I am doing the Load Balancing on two dynamic adsl. I have cisco 1721 with two adsl cards. I am doing NAT on the router for internal LAN going to internet. but apparently the loadbalancing doesn't work. I do NAT on the two interface dialer ( because it's dynamic ip). The connection always use the dialer1. here are the configs
any feedback will be appreciated
thank you very much
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 1/1
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
no fair-queue
interface ATM1
no ip address
pvc 1/1
dialer pool-member 2
no fair-queue
interface FastEthernet0
ip nat inside
speed auto
interface Dialer1
bandwidth 512
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username aaaaa pass bbbbb
interface Dialer2
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 1
ppp pap sent-username xxxx password yyyyy
ip nat inside source list 1 interface Dialer2 overload
ip nat inside source list 2 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 dialer1
ip route 0.0.0.0 0.0.0.0 dialer2
no ip http server
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 2 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
Bronze
Re: Load Balancing on two dynamic ADSL Connection
you'll need to change your nat config to something like this:
ip nat inside source route-map provider1-map interface Dialer1 overload
ip nat inside source route-map provider2-map interface Dialer2 overload
route-map provider1-map permit 10
match ip address 1
match interface Dialer1
route-map provider2-map permit 10
match ip address 1
match interface Dialer2
hth
Herbert
thanks for your reply..
one question, will it backup each other ? lets say one link is down, will I get 50% packet loss ?
regards
santo
Bronze
Good question.
Since your default routes point to Dialer interfaces, and Dialer interfaces are always up, both defaults will stay active even if one interface fails. So yes you will have 50% packet loss.
Not sure if/how this can be solved. I'm thinking along the lines of creating Dialer3 and Dialer4 and configure them as backup interfaces of the ATM interfaces. Then create default routes to them with a lower admin distance than to the Di1 and Di2.
Don't have any test equipment at hand unfortunately, but if you can, give it a try and let us know how it goes?
regards
Herbert
111
