Load balancing OSPF and 3DES
If I am load balancing between two sites using OSPF and I add 3DES with GRE. Will I have any problems with my load balancing?
Silver
Re: Load balancing OSPF and 3DES
you should have no problems as long as you have your pipes costed the same .
I was always told that you cannot loadshare across more than one IPSEC tunnel. Was I told wrong?
If you are running IPSEC over GRE, and only have one GRE tunnel, and per destination load balancing, there will be no load sharing.
109
