Community Member
Load balancing over two links belonging to two difference Line card
Does Cisco router support load-balancing over two OC-48c POS
links that belong to two different Line Cards? (Assuming 1 OC-48c POS port per Line Card).
Thanks in advance.
Yongjun.
1 REPLY
Bronze
Re: Load balancing over two links belonging to two difference Li
The router will automatically load balance over, up to 4, equal cost paths but on a per session, rather than on a per packet, basis so you may not get equal utilisation.
You can force load sharing on a per packet basis by disabling fast switching, 'no ip route-cache', on the interface but this is not recommedned as it will impact the router's performance.
204
