09-05-2002 01:54 AM - edited 03-02-2019 01:08 AM
i have a customer that is connected to my network with four serial links , and we are running BGP with this customer.
how can i load balance on the four links ???
09-05-2002 03:28 AM
Depends on how many routers are involved.
See link for details: http://www.cisco.com/warp/public/459/40.html
In the first example it has eigrp running between them, you most likely will use statics.
If it is like the second example, you can have 2 links to one router and two to the second and load balance on each via CEF or MLPPP.
You have many options.
09-05-2002 09:57 AM
Key to loadbalance .
U need at least two links between router for loadbalance .
Create BGP session between loopback interfaces and make sure they are reachable . either through IGP or Static routes . so try ping before you try to debug BGP problem . loopback should be pingable.
Make sure update-source will be loopback interfaces. and bgp-multihop should be configured for ebgp routers not directly connected to each other
I can post you teh config if u need more help let me know ur setup .
hope this make sense
