Community Member
Load Balancing with a 3500?
Is it possible to load balance with a Catalyst switch? Does it absolutely require a Content Switch?
1 REPLY
Bronze
Re: Load Balancing with a 3500?
"Load balancing" in of itself is a vague term that could mean any number of things. What specifically are you looking to do? Etherchannel is a form of load balancing on layer-2 switches, layer-3 switches/routers can load balance via static or dynamic routing, and content switches can get more fancy when load balancing to server clusters and so forth. Lots of options.
84
