Webcast-Catalyst9k
load balancing with eigrp
does eigrp load balance automatically, say I had 2 serials to one place, would it automatically load balance, how would I turn it off say on one link ?
Re: load balancing with eigrp
hi
AFAIK all the routing protocol does supports equal cost path load balancing.
if u dont want to have this behaviour i would suggest to try changing the delay on the interface (on which you dont want to pass the traffic in nomral conditions)which will change the cost and will turn off the loadbalancing on both the links..
regds
Bronze
yes it load balances automatically.
you can stop load balance between two serial ports by alteration delay or bandwidth value of serial interface.
what values are the delay at ? can you give me an example ?
thanks
Carl
hi
hope this link helps u out in tuning your delay parameter..
http://cisco.com/en/US/customer/tech/tk365/technologies_tech_note09186a00800c2d96.shtml
regds
114
