Load Balancing with Multicast
Hi Guys, We are having two equal cost paths and facing problem while configuring ip multicast with load balancing.We are using 2610 and 1750 series routers at diffrent ends.
Thanks in advance.
Pushpender
1 REPLY
Re: Load Balancing with Multicast
Hi.
You are probably having problems due to RPF. You have to configure a tunnel between the 2 routers and enable PIM on it. The preferred route for both routers to reach each other should be through the tunnel. By doing this when the routers perform RPF check, they will succeed, even though the packets are effectively using both paths.
Hope this helps.
NM
107
