Load balancing with serial and ethernet
noran01
Level 3
Level 3
We currently have the 3640 with a t1 connecting via serial interface and a handoff of a frac-t on an ethernet interface. I wanted to load balance this out using cef. I got the config running, but when will traffic switch onto the frac-t? i have per packet load balancing configured on both interfaces. but it seems the ethernet inerface is never utilized. can this even be done... i have two default router statements entered for each gateway.
11 Replies 11
Harold Ritter
you should be able to load-balance if you have the right configuration. Could you provide us with a "sh ip cef 0.0.0.0 int".
Thx
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
When i do that command this is the output:
0.0.0.0/32, version 0, receive
Here is the config that is under my e3/0 and s0/0 (the two interfaces i am trying to load balance)
interface Serial0/0
description :T-1 circuit
ip unnumbered FastEthernet0/0
ip load-sharing per-packet
interface Ethernet3/0
description :frac t-1
ip address x.x.x.x 255.255.255.240
full-duplex
Thanks...
can you check for
show cef drop
show ip cef internal
sh ip cef 0.0.0.0 0.0.0.0 detail
Here is the output:
DR2-R1#sh cef drop
CEF Drop Statistics
Slot Encap_fail Unresolved Unsupported No_route No_adj ChkSum_Err
RP 290731 1 0 52 0 0
DR2-R1#sh ip cef in
IP CEF with switching (Table Version 59), flags=0x0
28 routes, 0 reresolve, 0 unresolved (0 old, 0 new)
28 leaves, 15 nodes, 19132 bytes, 95 inserts, 67 invalidations
1 load sharing elements, 328 bytes, 1 references
universal per-destination load sharing algorithm, id DAD809D8
3 CEF resets, 1 revisions of existing leaves
refcounts: 4136 leaf, 4096 node
Adjacency Table has 7 adjacencies
0.0.0.0/0, version 30, attached, per-packet sharing
0 packets, 0 bytes
via Serial0/0, 0 dependencies
traffic share 1, current path
valid adjacency
via Ethernet3/0, 0 dependencies
traffic share 1
valid glean adjacency
0 packets, 0 bytes switched through the prefix
tmstats: external 0 packets, 0 bytes
internal 0 packets, 0 bytes
Load distribution: 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 (refcount 1)
DR2-R1#sh ip cef 0.0.0.0 0.0.0.0 detail
0 packets, 0 bytes
valid adjacency
traffic share 1
ruwhite
Level 7
Level 7
The bandwidths on these two are probably completely different--how are you learning the default over each interface? Is it two statics, or learned through some protocol, or (?). Could you do a show ip route 0.0.0.0 and post it here?
Russ.W
I have two default routes set up (static)
ip route 0.0.0.0 0.0.0.0 s0/0
ip route 0.0.0.0 0.0.0.0 e3/0
can you try using the next hop IP address insted just interface.
example:
ip route 0.0.0.0 0.0.0.0 192.168.0.1 s0/0
ip route 0.0.0.0 0.0.0.0 192.168.1.1 e3/0
I would definitely use the next hop instead of the interface, for several reasons. First, and foremost, pointing a default at a broadcast interface is never a good idea. It will result in arp cache entries for every possible ip address reached through the default route, and will probably mess up your load sharing, as well as cuase you numerous headaches in the area of memory consumption and processor utilization.
Use the next hops, as in the example above, and see what difference that makes.
Russ.W
ok I changed the default route for the ethernet interface to point to the next hop ip address instead and it seems some traffic is flowing over it, but not as much compared to the serial link...
Now when i do a sh cef drop i get this:
Router#sh cef drop
CEF Drop Statistics
RP 1225 863 0 0 0 0
I see it working a little better now but its actually hurting performance....all our inet traffic is going through a pix which is doing PAT and its causing major slowdowns....
Why dont you use Per-destination load balancing? You have 2 dissimilar bandwidth links, so u better use per destination. In CEF per destinaiton load blancing takes SOURCE+DESTINAITON hash, so you can have better usage and performance as well.
