01-16-2004 10:30 AM - edited 03-02-2019 12:56 PM
Wondering is its possible to do load balancing with a 2924 running ent.
01-16-2004 10:34 AM
Like etherchannel? Yeah.
01-16-2004 10:51 AM
Sorry - I should have been more specific. I have 4 windows 2000 servers that I want to balance. They all have the same apps, etc. and am looking to do something similar to what the F% Big IP 1000 can do, just with a cisco box
01-16-2004 03:22 PM
You need to use a Local Director or a content switch to achieve this. If you are running advanced server you can cluster the boxes which would achieve the same end. You can also round robin in DNS.
Hope this helps
Richard
