Community Member
Load Balancing
Is it possible to load balance between two ports on a 2924XL and a 1548?
Community Member
Re: Load Balancing
You should be able to load balance between the ports just by putting in route statements or default gateways pointing out the ports.
Community Member
Re: Load Balancing
Unless You have a trunk port on L2 switches You can't load balance.
110
