load balancing
Can we configure load balancing between two ISP without BGP .
We are giving a 512 link to customer .
He is taking other 512 k from other service provider .He wants loadbalane the traffic .
Can you just send me the confiuration .
VIP Purple
Re: load balancing
Depends on what routing protocol you are running on your side, and what hardware you are using. Can you post this info ?
Georg
Re: load balancing
We are the ISP we are using BGP at our end .
Customer has 1700 cisco router & L3 switches .
Can you send us the configuration to load balance .
Thank you
Re: load balancing
Israr:
Most ISPs won't let you run anything else besides BGP with them. The main implication here is that you can really only use default static routes to load share.
ip route 0.0.0.0 0.0.0.0 serial0/0
ip route 0.0.0.0 0.0.0.0 serial0/1
...and source a default route into the rest of your network from here. The mechanism for that depends on the IGP that you're using.
Alvaro.
Bronze
Re: load balancing
It seems you would give the customer a block of IPs as would the other ISP. His best bet to load balance is to use the two blocks of IPs in conjunction with Policy Based Routing. Basically, he could assign (or through NAT) half of his hosts with your IPs and the other half with the other ISPs' block on his router, then policy route from his router based on what the source IP is to the appropriate ISP.
Re: load balancing
Thats right we are giving the ip block to them .
They have 1700 router at there side & Layer 3 switch .
I need configuration can you just send me the
configuration example Of NAT & policy based routing .
109
