I assume that u want to distriute load on 2 lease line.
so what u can do is - keep one default gateway on client side i.e use only one ethernet port and create route-maps to distribute load on lease lines.
Now if u want to use both the ethernet ports then u can't keep both ethernet in same subnet , u have to have ip addresses on all interfaces in different subnets.Only way is use HSRP.
