Webcast-Catalyst9k
Load balancing
Please help to do load balancing from one Cisco router 2620 to 2 remote locations. Here is our intended config on 2620:
ip route 10.0.0.0 255.255.255.0 192.168.1.1
ip route 10.0.0.0 255.255.255.0 192.168.2.1
Thanks for all comments.
Re: Load balancing
Are you having two wan links between the two locations ? The above routes should help you load balance. Additionally you can enable CEF ("ip cef" command) and also the following command under the serial interface.
int s0/0
ip load-balancing per-packet
int s0/1
ip load-balancing per-packet.
The above configuration is good if you are using only data. If you are using Voice over IP, the above is not a recommended configuration, because voice packets can come out of order before playout at the remote end.
Gold
Re: Load balancing
I wouldn't use per packet load sharing at all, out of order packets will always cause problems, even for HTTP and FTP traffic.
Russ.W
Re: Load balancing
Hi Russ,
Do you have any suggestion what should we do ? Thank you very much.
Duc Vu
Gold
Re: Load balancing
Using two static routes would be fine, as long as you have corresponding statics on the other routers to direct traffic back. I do think your statics might be a little off, though:
Are you certain the IP addresses are in the 10.0.0.x range? Or are they really 10.1.1.x, or did you intend for the subnet mask to be 255.0.0.0 (which would be a lot of address space, and I'm not certain that's right, either).
Two statics like this will per source/destination address load share, which should be fine. It won't be "perfect," in that it won't make the links run 50%/50%, but it should do pretty good, and give you good application performance, as well.
Russ.W
Re: Load balancing
Hi Russ,
The subnet 10.0.0.0 is just an example. Thank you for your help.
Duc Vu
Re: Load balancing
Yes, we have two wan links to remote locations. About CEF, do we need certain IOS images ? thank you very much.
Duc Vu
Gold
Re: Load balancing
CEF is the default switching path on every cisco router except some of the ones that have hardware switching paths, and the 800, which doesn't support CEF, if I remember right. As long as you're somewhere above 12.0 or so (or maybe it's 11.3), you should have CEF, and it should be enabled.
Russ.W
99
