tb
Load-Balancing
i try to load-balance over a GRE tunnel and a E1 PRI.
I dont get it to work, sh cef inter seri0/0 tells me
Packets switched to this interface are dropped to the next slow path: Compression
But i have removed the compress stac instruction.
ip cef and ip route shows me both links as Equal-Cost-Path.
But the router uses only the Tunnel interface.
Someone knows the problem?
I using ios 12.3(6a) and one 2621 and 2620.
Thanks for your answers.
cu thomas
1 REPLY
tb
Re: Load-Balancing
Nobody has tried it bevor?
cu thomas
87
