Webcast-Catalyst9k
Load Balancing
Wondering is its possible to do load balancing with a 2924 running ent.
GW6
Re: Load Balancing
Like etherchannel? Yeah.
Re: Load Balancing
Sorry - I should have been more specific. I have 4 windows 2000 servers that I want to balance. They all have the same apps, etc. and am looking to do something similar to what the F% Big IP 1000 can do, just with a cisco box
Re: Load Balancing
You need to use a Local Director or a content switch to achieve this. If you are running advanced server you can cluster the boxes which would achieve the same end. You can also round robin in DNS.
Hope this helps
Richard
109
