Load Balancing
How i can configure load balancing betwen 2 serial line (1 T1 and 1 64Kbps) and at the same time if the T1 serial link goes down the 56Kbps line stay up..
1 REPLY
noc
Re: Load Balancing
if this is an internet connection you have far less options than if this is a wan connection to another router you control (i.e. a point to point setup)
For internet access, use floating static routes, for
point to point links run EIGRP and mess with variance etc, to keep a failover scenario in place based on routing advertisements. Your Dialer can be kept up, by matching an route or a protocol type
117
