Community Member
load balancing
Here is my problem. I have a building switch that supports dual trunk uplinks to the core. The building switch supports a single vlan. Is there a way to load balance the single vlan across the dual uplinks back to the core? Thanks
1 REPLY
Community Member
Re: load balancing
I believe you would want to create an etherchannel between the two links.
86
