Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Load Balancing
I have 2 routers at each end connected with two 512 kbps serial links. I would like to load Balance this links. How do I configure the routers to do load balancing. Also Iam doing End to End Encryption.
Bronze
Re: Load Balancing
The switching mode will automatically load balance, as long as the routing table shows all routes via both interfaces. Process switching (least recommened) will load balance per packet, fast or CEF (recommended) switching will load balance per destination.
Re: Load Balancing
I have a 3640 Router with 4 ethernet interfaces. Only one to the inside Network. The 3 other interfaces connected to the Internet each to a satellite system (all with fixed bandwidth). Do you suggest a solution to load-balance the 3 interfaces into the 4th (LAN)?
152
