Load Balancing
Hi! I am having load balancing problems in my environment and I would like a help.
I have updated 02 Cisco 1700 routers to 02 2610MX routers (importing the configuration file) and the load balancing stops working. Only the router 1 is working.
My environment has 02 leased lines, 02 Cisco 2610XM routers and 01 Cisco 3550 switch (vide attachment).
Actually, all ports of my switch are working as switchport and the routers' configuration are:
ROUTER1
interface Tunnel0
bandwidth 256
ip address 172.16.62.54 255.255.255.252
keepalive 10 3
tunnel source 172.16.62.46
tunnel destination 172.16.62.45
interface FastEthernet0/0
ip address 10.150.21.254 255.255.255.0
duplex auto
speed auto
no mop enabled
standby ip 10.150.21.1
standby preempt
standby track Tunnel0
interface Serial0/0
bandwidth 256
ip address 172.16.62.46 255.255.255.252
no fair-queue
router bgp 11
bgp log-neighbor-changes
neighbor 10.150.21.253 remote-as 10
maximum-paths 2
address-family ipv4
neighbor 10.150.21.253 activate
maximum-paths 2
no auto-summary
no synchronization
exit-address-family
address-family nsap
maximum-paths 2
no synchronization
exit-address-family
ROUTER 2
interface Tunnel1
bandwidth 256
ip address 172.16.62.58 255.255.255.252
keepalive 10 3
tunnel source 172.16.62.50
tunnel destination 172.16.62.49
ip address 10.150.21.253 255.255.255.0
duplex auto
speed auto
no mop enabled
standby preempt
standby track Tunnel1
interface Serial0/0
bandwidth 256
ip address 172.16.62.50 255.255.255.252
no fair-queue
crypto map sof-fase2
router bgp 10
neighbor 10.150.21.254 remote-as 11
maximum-paths 2
address-family ipv4
neighbor 10.150.21.254 activate
maximum-paths 2
no auto-summary
no synchronization
exit-address-family
address-family nsap
maximum-paths 2
no synchronization
exit-address-family
Rodnei
1 REPLY
Re: Load Balancing
The only difference i could observe here is the crypto map which is missing in serial 0/0 of the first router..
interface Serial0/0
bandwidth 256
no fair-queue
interface Serial0/0
bandwidth 256
no fair-queue
can u confirm whether both the boxes are loaded up with same ios code ??
also did u miss up that config line while copying up the configs ??
do add it up and check out ...hope that will fix up the probs.
regds
113
