Webcast-Catalyst9k
Load Director and Database (SQL?)
Hi, I have a 416 Load Director. I was wondering if this can be used for a SQL database?
Can the 416 load direct any ports or is it only FTP, SMTP, DNS, Telnet, Web?
1 REPLY
Re: Load Director and Database (SQL?)
SQL uses tcp and udp ports 1433 and 1434
So i think you should be able to load direct using the virtual and bind commands with appropriate ports specified. A sample would look like this
virtual 10.10.10.1:1433:0:udp is
bind 10.10.10.1:1433:0:udp 10.10.10.2:1433:0:udp
Hope that helps. Give it a try!
95
