Load sharing over two unequal routes.
I have a frame relay network with each remote node having two separate unequal paths back to the host node.
The remote sites have 2620's with 1-768k and 1-56k frame relay link to the host 7206.
The host has 2 separate 768k links, each with a link to the remotes.
The plan was to have the 56k as a backup interface, but would now like to evaluate the possibilities of having the 56k link share some of the load.
What would be the best way to utilize the bandwidth of both links and have a form of redundancy?
-Rick
1 REPLY
Re: Load sharing over two unequal routes.
Below are links with information on load balancing:
Load balancing with Cisco Express Forwarding
http://www.cisco.com/en/US/partner/products/hw/modules/ps2033/prod_technical_reference09186a00800afeb7.html
How Does Unequal Cost Path Load Balancing (Variance) Work in IGRP and EIGRP?
http://www.cisco.com/en/US/partner/tech/tk365/tk207/technologies_tech_note09186a008009437d.shtml
410
