Load Sharing using VWIC-2MFT-T1=
Dear Friends,
I have a VWIC-2MFT-T1= CARD, what I would like to do is share the internet traffic on the 2 ports of the vwic card.
Things that I have:
Both the T1's are coming from the same ISP.
T1 have different network address and subnet mask.
Please let me know if you need to know anything else.
Amit Sonik
1 REPLY
Gold
Re: Load Sharing using VWIC-2MFT-T1=
Do you mean load share inbound or outbound? I presume both... Inbound is hard, outbound is (generally) easy. You should just be able to set up static default routes (0/0) out each serial, and get fairly decent load sharing outbound. Since both links are to the same isp, peering using bgp to them across loopbacks (using multihop), advertising your network, and just accepting a default, might be an option as well.
Russ
105
