Loadbalancing with MCFC2 per-packet configuration working not well
I have a Catalyst 6509 with a Sup2 and MSFC2. We have two WAN links to a remote site and would like to do a load balancing per-packet basis. The MSFC2 has the following configuration.
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip load-sharing per-packet
interface Vlan20
ip address 192.168.20.1 255.255.255.0
router eigrp 1010
network 192.168.10.0
network 192.168.20.0
no auto-summary
no eigrp log-neighbor-changes
The sh ip route show me two routes to network 192.168.40.0/24 with the same metric.
192.168.30.0/30 is subnetted, 2 subnets
D 192.168.30.4 [90/2170112] via 192.168.20.3, 00:09:26, Vlan20
D 192.168.30.0 [90/2170112] via 192.168.20.2, 00:09:26, Vlan20
C 192.168.10.0/24 is directly connected, Vlan10
D 192.168.40.0/24 [90/2195712] via 192.168.20.3, 00:01:29, Vlan20
[90/2195712] via 192.168.20.2, 00:01:29, Vlan20
C 127.0.0.0/8 is directly connected, EOBC0/0
C 192.168.20.0/24 is directly connected, Vlan20
The ip cef 192.168.40.0 show me the MSFC2 should do load balance per packet over the two wan links to the network 192.168.40.0.
RT1#sh ip cef 192.168.40.0
192.168.40.0/24, version 25, per-packet sharing
0 packets, 0 bytes
via 192.168.20.3, Vlan20, 0 dependencies
traffic share 1, current path
next hop 192.168.20.3, Vlan20
valid adjacency
via 192.168.20.2, Vlan20, 0 dependencies
traffic share 1
next hop 192.168.20.2, Vlan20
valid adjacency
0 packets, 0 bytes switched through the prefix
RT1#
if I do a ping from host 192.168.10.3 residing on the network 192.168.10.0/24 to the host 192.168.40.1 on network 192.168.40.0/24 the serial interface show me unequal load on the two links.
Link1 Link2
RT1 RT2
TX 20/255 TX 20/255
RX 41/255 RX 1/255
I made also a debug on both links. The debug on link1 shows me icmp echo request and replays but on the link2 there are only icmp replays, no icmp echo request packets.
Thanks for any recommendations,
Rolf
1 REPLY
Bronze
Re: Loadbalancing with MCFC2 per-packet configuration working no
Hi Rolf,
Are the two WAN links of equal cost? If not the variance command has to be enabled to do unequal cost load balancing.
Please check that.
The following is a doc on Troubleshooting Load Balancing Over Parallel Links Using Cisco Express Forwarding. It might be able to help you diagonise and solve the problem.
http://www.cisco.com/en/US/tech/tk648/tk365/technologies_tech_note09186a0080094806.shtml
94
