Webcast-Catalyst9k
Loadsharing the BGP traffic between two default routes to two different providers
A single router is connected to two different ISPs using BGP, it uses two default routes to the two ISPs, how can I load balance the outgoing traffic between my two links.
1 REPLY
Anonymous
N/A
Re: Loadsharing the BGP traffic between two default routes to tw
If you config the 2 default routes to their next hop addresses, their metric will be the same, i.e. 1. Then the router will load balance all outgoing traffic. By default, this is load-balanced by per-destination. If you are using default routes, BGP is of no use at all here. Hence don't make your network complicated by using BGP.
705
