Community Member
LocalDirector 416 and UDP fragmented packets
I have Cisco LocalDirector 416 with software ver. 4.2.3. When UDP static translation configured, the LD does not translate fragmented UDP packets from real server and drops them. Does anyone have an idea on how to solve that problem ?
Community Member
Re: LocalDirector 416 and UDP fragmented packets
You can set up the syslog server so that you will be able to log the translation error.Once you have the log,you can isolate the issue.
For this, you can go through the following URL:
http://www.cisco.com/warp/public/117/setup_ld_syslog_3995.html
Community Member
My syslog server is installed and hasn't any translation errors.
In Release Notes for Cisco LocalDirector (ver. 4.2.4) I have found my caveat:
CSCdy37648
"For defined UDP static translations, the LD does not translate fragmented packets."
It is a bug.
103
