localdirector load balancing
we have a LocalDirector 416 with V 3.1.4. We want to perfom "on virtual server and multiple real servers". The configuration is:
localdirector# sh conf
: Saved
: LocalDirector 416 Version 3.1.4
syslog output 20.3
no syslog console
hostname localdirector
no shutdown ethernet 0
no shutdown ethernet 1
no shutdown ethernet 2
interface ethernet 0 auto
interface ethernet 1 auto
interface ethernet 2 auto
mtu 0 1500
mtu 1 1500
mtu 2 1500
multiring all
no secure 0
no secure 1
no secure 2
ping-allow 0
ping-allow 1
ping-allow 2
ip address 172.28.3.100 255.255.248.0
route 0.0.0.0 0.0.0.0 172.28.0.5 1
no rip passive
rip version 1
failover ip address 0.0.0.0
no failover
telnet 172.29.14.0 255.255.255.0
snmp-server enable traps
no snmp-server contact
no snmp-server location
virtual 172.28.3.101:0:0:tcp is
predictor 172.28.3.101:0:0:tcp roundrobin
real 172.28.5.10:0:0:tcp is
real 172.28.0.19:0:0:tcp is
name 172.28.5.10 gred01
name 172.28.0.19 ras
bind 172.28.3.101:0:0:tcp 172.28.5.10:0:0:tcp
bind 172.28.3.101:0:0:tcp 172.28.0.19:0:0:tcp
We can ping the virtual ip, but when we make "telnet virtual_ip", the connections with the real servers doesn´t establish.
With the command "show real" we see that it has a connection open with one of the real servers, but the telnet doesn´t work. The message is:
telnet 172.28.3.101
Trying...
telnet: Unable to connect to remote host: Connection timed out
Thanks you.
Bronze
Re: localdirector load balancing
I think the local director itself will respond to the ping if it has connectivity to atleast one of the real servers. But, when you use telnet, there will be a separate TCP connection betweeen the client and LD, and between the LD and real server. So if the real servers do not accept TCP connection for some reason, this might fail. Probably, you can try ping and telnet to the real servers directly and see what is happening. If that does not work, then the problem may not be with LD. You can also check whether there are any filters like access-lists between the source and destination that blocks telnet.
Thank you for your answer, but it's not the situation.
I can make telnet to real servers directly from the clients.
One of the real servers is a router, and I have made a "debug ip tcp packets" and I can see a packet with the ip address of the client trying to establish a connections to the router on port 23, but the connections is closed, I don't know why.
ip client: 172.29.14.12
ip_virutal: 172.28.3.101
ip_real_server:172.28.0.19 (it's the router)
debug ip tcp packet:
tcp0: R SYNRCVD 172.29.14.12:3382 172.28.0.19:23 seq 2292460683
OPTS 4 ACK 694291197 SYN WIN 4128
tcp0: I SYNRCVD 172.29.14.12:3382 172.28.0.19:23 seq 694291197
RST WIN 0
And with 'debug ip transactions"
TCP0: state was LISTEN -> SYNRCVD [23 -> 172.29.14.12(3410)]
TCP0: Connection to 172.29.14.12:3410, received MSS 1460, MSS is 516
TCP: sending SYN, seq 2544725774, ack 694543400
TCP0: Connection to 172.29.14.12:3410, advertising MSS 556
CP0: RST received, Closing connection
TCP0: state was SYNRCVD -> CLOSED [23 -> 172.29.14.12(3410)]
tcp0: T CLOSED 172.29.14.12:3410 172.28.0.19:23 early close
TCB 0x80F08920 destroyed
Felisa
Do you have any alternate path that will bypass the LD? All the traffic between client to real server have to pass through the LD, even after the session is established client and real server.
100
