09-17-2001 03:44 PM - edited 03-01-2019 06:46 PM
Should machines behind a LocalDirector be able to see a LocalDirector virtual address, either its own or another virtual address?
For instance, if I have machines A and B load-balanced as virtual address A-B, and machines C and D load-balanced as C-D, should either A or B be able to see A-B or C-D? Currently we cannot, and I suspect a routing issue, but I want to make sure it's possible first.
09-18-2001 12:09 AM
The LDIR CANNOT do routing. If you have AB and CD
on different subnets, you need a router to do routing between the subnets. If you _do_ have a router, then define 'see' - e.g. do you mean ICMP ping or?
/Johnny
09-18-2001 12:11 AM
Oh, forgot, you can do semi-routing by giving the LDIR an alias address - use alias command.
Also, is you do not use the secure command, you
can use the LDIR as a bridge - e.g. if the AB and CD
systems are on different physical interfaces of the LDIR. Still need a router though, if on different subnets.
/Johnny
09-19-2001 08:38 AM
Thanks. Good information. All addresses are on the same subnet, and therefore I believe all are coming off the same interface as well.
09-19-2001 09:07 AM
What you have to consider then, is that you
cannot load balance on a single interface of an LDIR.
Traffic :has: to pass from one interface to another in order to do load balancing. However, you
should be able to ping any station in any case,
if you leave 'secure off' and have the proper
alias and corresponding failover alias addresses
defined.
/Johnny
