Lock and Key ACL outbound on Dialer Interfaces?
I am try to set up Lock and Key ACLs on dialer interfaces on a 2610. I want it for outbound traffic. Everything looks ok. However, when I telnet to the dialer interfaces IP and log in I get a message saying:
No input access group defined for Ethernet0/0.
What little information I can find on Lock and Key indicates you can put the ACL on any interface in or out. I am missing something here? Here is the part of my configuration that addresses the Key and Lock ACL.
Current configuration : 29521 bytes
version 12.2
hostname router
username testuser password testpass
interface Ethernet0/0
ip address 192.168.1.3 255.255.255.248
ip nat inside
half-duplex
no cdp enable
interface Group-Async1
no ip address
encapsulation ppp
dialer in-band
dialer pool-member 1
async mode dedicated
ppp authentication chap
group-range 33 40
interface Dialer1
description testdial
ip address 172.20.11.10 255.255.255.240
ip access-group 102 out
ip nat outside
dialer pool 1
dialer remote-name remotesite
dialer idle-timeout 45000
dialer string 628
dialer-group 1
no cdp enable
access-list 102 remark Testing Dynamic ACL
access-list 102 dynamic testacl timeout 120 permit ip any any log
access-list 102 permit tcp any host 172.20.11.10 eq telnet
access-list 102 deny ip any any log
line vty 0 4
password termpass
login local
autocommand access-enable timeout 5
end
Thanks Much!!!
Chuck Glover
Re: Lock and Key ACL outbound on Dialer Interfaces?
I have never seen this done with an acl out, only in. Makes sense as you must telnet into the router first, get authenticated, then the dynamic acl is created allowing you access. Change the access-group to in and see what happens.
This is a good link on lock and key: http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a00800d9814.html
Hope it helps.
Steve
Bronze
I assume what you want here is for people to dial in, enable lock and key via telnet, and then be able to get access to networks behind the 2610, with the access-list restrictions being placed on packets OUT OF the 2610, towards the dial in client. Anything else would not make any sense.
Note that since your dynamic access-list permits any any, it could just as well be placed inbound. Note too that an inbound list saves processing/network time; any packets denied will be dropped. For outbound, all inbound packets would be accepted, routed, responded to, routed back, and then dropped. It would make no sense to want this. I can't see where it's mentioned that outbound is not supported in the docs, yet looking at the code I see that one of the first checks we do is for an inbound access-list, so I don't believe that outbound is supported.
200
