Community Member
Lock DTE speed
I want to lock the dte speed on as5800 and as5300, when I use the speed command under the line configuration mode nothing is happend and the speed is the same.
I think i can configure it using the modem cap database.
does anyone know how to lock the dte speed ?
the modems are MICA in both 5300 and 5800
Silver
Re: Lock DTE speed
Yes, we can lock the dte speeds using amodemcap..the "s" registers here to look for are s29, s30, s31,s50,s51,s64.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_serv/5300/sw_conf/sw_ports/at_set/atcmnds.htm
In order to apply a modemcap, do the following:
router#debug confmodem
router#term mon
router#conf term
router(config)#modemcap edit MODEMCAPNAME misc INITSTRING
router(config)#line BEGIN END
router(config-line)#modem autoconfigure type MODEMCAPNAME
Community Member
Re: Lock DTE speed
I don't want to lock the connected speed , I want to lock the dte speed between the dte ( AS ) and the mica modem (dce)
Silver
Re: Lock DTE speed
Maybe I misunderstood your requirement...locking dte speed is done under the line commands & locking modem connect speeds (dce) is done using the modemcap.
After configuring the line speed, do a "show line" to see the changes have taken effect...try clearing the line using "clear line x"
Just wondering why you need to lock the dte speed?
Mak.
147
