Lock speed/duplex on Gigabit-interface in Catalyst 3750?
How do I lock speed to 1000 and Duplex to full on a switch-interface in a Catalyst 3750? Default is "Auto-duplex, Auto-speed" and the only relevant command I can find is "speed nonegotiate" but even with this command on an interface show interface saids Auto, Auto.
Thanks in advance
Jimmy Larsson
CCNA, CCNP, yada yada yada. ;)
  • Other Network Infrastructure Subjects
Re: Lock speed/duplex on Gigabit-interface in Catalyst 3750?
I take it you are trying to configure the speed\duplex on one of the fiber ports (gi1/0/25, 26, etc). My understanding of it is that the fiber ports, being that they have gig fiber modules in them, the speed\duplex cannot be negotiated, it is always gig\full.
No, I want to lock the speed to 1000 and duplex to full on the GigabitETHERNET ports. Is that possible?
/Jimmy
A gigabit interface does 1000 Mbps only and hence you do not have options to hard set speed. If you have a 10/100/1000Mbps interface, you can hard set speed.
I have a 3750 sitting here with the GigabitEthernet ports. I was able to nail the speed at 1000 (or whatever) but was not able to specify duplex. Apparently if it's Gigabit capable, it's always full.
SK#config t
Enter configuration commands, one per line. End with CNTL/Z.
SK(config)#int gi1/0/18
SK(config-if)#speed 1000
SK(config-if)#duplex full
Gigabit port is restricted to full duplex
SK(config-if)#
Hope this helps
As I said it depends on what type of interface you have. You have a 10/100/1000 Mbps interface.
Here are the options for a 1000Mbps only interface
Switch(config)#int gig 1/0/1
Switch(config-if)#speed ?
nonegotiate Do not negotiate speed
Here are the options for a 10/1000/1000Mbps interface
Switch(config-if)#int gig 2/0/1
10 Force 10 Mbps operation
100 Force 100 Mbps operation
1000 Force 1000 Mbps operation
auto Enable AUTO speed configuration
8353
