Community Member
Logging Ethernet connection and disconnection events
This should be an easy one, but it's driving me crazy. I have a Cat4506 with 3 48-port 10/100 blades. The switch is not generating a log event when new Ethernet connections are plugged in.
For example, on port fa4/47, I plug a connection in, and by doing a sho fa4/47 I see that the interface has transitioned from notconnect to connect. The system never generates a log event, though, and I need these logs.
Here's the result of my "sho logging":
dal-swc-i-1#sho logging
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns)
Console logging: level debugging, 7 messages logged
Monitor logging: level debugging, 0 messages logged
Buffer logging: level debugging, 7 messages logged
Exception Logging: size (40960 bytes)
Trap logging: level debugging, 12 message lines logged
Logging to 172.18.0.222, 12 message lines logged
I don't see the logs show on either the loghost or on the console. What's up?
--Peter
1 ACCEPTED SOLUTION
Re: Logging Ethernet connection and disconnection events
Logging of link up/down messages is disabled by default in Native IOS. You'll need to have "logging event link-status" configured if you want these messages
interface GigabitEthernet1/1
no switchport
ip address 10.1.1.1 255.255.255.0
logging event link-status <<<-----
Silver
do a show logging buffer 1024
Silver
also make sure you have
set port trap mod/port enable
you can also set udld on the ports
see this page
http://www.cisco.com/en/US/products/hw/switches/ps679/products_configuration_guide_chapter09186a008007ef3b.html
no switchport
179
