06-12-2003 09:26 PM - edited 03-02-2019 08:06 AM
We have IOS routers (12.1(16) that make and receive hundreds of ISDN calls per day. The routers also have a number of serial interfaces. These routers are logging events to a syslog server.
We do not want to fill our syslog server with logs associated with ISDN calls (Dialer interface changed to up, etc.).
However, to stop Dialer interface state changes from being logged, we need to set the logging trap level to critical. By doing this, we miss being notified of significant events such as config changes or other interface state changes.
Is there a way we can configure the router to demote the severity level of Dialer interface state changes so we can set the logging trap level to warnings or notifications and not be bombarded with Dialer interface state changes?
Many thanks in advance for any suggestions.
Chris
06-12-2003 10:39 PM
I don't know of a way to reset the severity, but if you consider Dialer interface state changes to be totally uninteresting, you may set "no logging event link-status" on the Dialer interface to prevent it from being logged at all. You continue to get any AAA accounting data you may be recording, and debugs still work.
06-12-2003 11:12 PM
I have the same question and already tried to put "no logging event link-status" on both the physical (PRI D-channel) and the dialer interface, but I still get
%DIALER-6-BIND
%LINK-3-UPDOWN
%LINEPROTO-5-UPDOWN
%ISDN-6-CONNECT
and at disconnect:
%ISDN-6-DISCONNECT
%LINK-3-UPDOWN
%DIALER-6-UNBIND
for each call... any suggestions to lower the amount of logs is welcome.
tia
Herbert
