Logging level on a C2950-24
The following is from a C2950-24:
%SPANTREE_FAST-7-PORT_FWD_UPLINK: VLAN0032 FastEthernet0/24 moved to Forwarding (UplinkFast).
And this is from a C2924-XL:
%SPANTREE_FAST-6-PORT_FWD_UPLINK: Port FastEthernet0/24 in vlan 9 moved to Forwarding (UplinkFast).
Is there a way to change the "spantree" logging level (in the C2950) from 7 to 6? I have "logging trap 6" on both switches, so level 7 messages aren't logged.
I know level 7 is meant for debug reasons, and i believe C2950 has it wrong, since this not a debug message. Of cource i can change the logging level of C2950 to 7 but that's not a right solution, since it should be used only for debug purposes.
1 REPLY
Bronze
Re: Logging level on a C2950-24
I do not think that you can set debug levels feature wise on IOS based switches. It is possible only with the set based switches.
137
