Logging on using a browser
Does anyone know how to set up a router/switch to allow access via http.
We have a range of switches/routers
Any help appreciated
1 ACCEPTED SOLUTION
Re: Logging on using a browser
on a router...use "ip http server" to enable.
on most of the newer fixed config switches, it's on by default i believe.
what types of switches you are talking about..
On the lower end switches, you need to have esp softwares to load to run http service...
for 4.5 n 6k
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/cfgnotes/78_10697.htm
and for small end switches.. you have to make sure you have tar file has loaded with html files
http://www.cisco.com/warp/customer/473/59.html
hope this helps
471
