Community Member
Logging VoIP Calls detail
I have set up a syslog daemon using Kiwi Syslog Daemon. And setup my router to send SNMP traps dial to this server.
I'm able to see the message being logged, however, I'm having trouble interpreting the message. What I see in the message, is the PID of the dial peers, the peer address and some other numbers.
Is there a way to quickly "decode" all this information and save them in a CSV format file ?
thanks
norman
Silver
Re: Logging VoIP Calls detail
Cisco has a error message decoding tool in their support website. You paste the message and get the decoded text. I guess you will need a valid login to the site to use this tool.
Community Member
Alright. I will check it out. Thanks!
153
