08-06-2002 01:00 AM - edited 03-02-2019 12:27 AM
We have a central switch (CAt4k6) with a Flat network .The workstations ping each other at <10ms but the NT Login takes place fter 2 attempts. What can be possible issues ?
Regds/-
Kaustav
08-06-2002 01:18 AM
ping the workstations using names and not the IP, see if you still get <10ms or there is some latency issues or WINS/DNS issues etc.
R/Yusuf
08-06-2002 01:54 AM
Check port and NIC speed and duplex settings. There can be problems if both sides are in auto.
