loopback interface on catalyset switches
I need to know if I can configure loopback interfaces on L2 switches (2950) and if yes , in which IOS
Moamen
1 ACCEPTED SOLUTION
Re: loopback interface on catalyset switches
Hi Moamen,
The software will show you the presence of loopback option after interface command but this command is not supported in hardware as it is a layer 2 switch.
The IOS developed by Cisco is the general release and has some common commands but those commands will only be working if proper hardware is found.
A software loopback is a layer 3 interface and the 2950 is a layer 2 switch;the switch would need to support L3 for a loopback to work.
So this will not work on 2950 switch but will work on 3550 switch and above which are layer 3 switches.
HTH, please rate all post.
Ankur
Hi Moamen,
As the 2950 is a pure 2nd layer switch, you can only have one active 3rd layer interface on it at any given time. The most logical and usual option is to use a VLAN interface - in fact, I don't think you can use any other type of 3rd layer interface on them.
Ankur
Purple
Why would you think you need to use a loopback interface on a layer 2 switch ???
for admin, I need to create loopback interface and use it as the admin IP to reach the switch
I know that the admin ip configured under interface vlan1
but I'm asking because I have a switch that has the int loopback in his menu when using
conf t# int ?
I can found loopback , but I can't configured it
switch(config)#interface ?
Async Async interface
BVI Bridge-Group Virtual Interface
Dialer Dialer interface
FastEthernet FastEthernet IEEE 802.3
Group-Async Async Group interface
Lex Lex interface
Loopback Loopback interface<<<<<
Multilink Multilink-group interface
Null Null interface
Port-channel Ethernet Channel of interfaces
Tunnel Tunnel interface
Virtual-Template Virtual Template interface
Virtual-TokenRing Virtual TokenRing
Vlan Catalyst Vlans
range interface range command
System image file is "flash:c2950-i6q4l2-mz.121-22.EA3"
but when I'm trying to configure it the switch refused
Thanks & BR
Moamen
Hi Moamen,
Ankur
Hello Ankur
Thanks very much , it is clear now
Moamen
203
