06-22-2006 04:12 AM - edited 03-03-2019 03:46 AM
Hello
how can i lose the static route entry, if the Host in the Lan not reachable.
interface Ethernet 0
ip address 172.26.26.5 255.255.255.224
ip route 10.0.0.0 255.0.0.0 172.26.26.15
ip route 10.0.0.0 255.0.0.0 172.26.26.10 200
I want to use the route via 172.26.26.10 if the 15 isn't present.
I hoped that the command : no ip proxy-arp
on the LAN Interface, bring my static-route down, when the Host isn't in the arp-cache. But ... :?
06-22-2006 04:45 AM
I believe you are looking for a reliable static routing correct?
This can only be done in a couple of ways in a couple of IOS in a couple of platforms.
The problem with multiaccess interfaces is that it will not go down if a single "host" goes down, so interface will be always up, and your router will not use 172.26.26.10.
You need to create a tracking way for the .15 (using ping for instance).
Check this link:
Reliable Static Routing Backup Using Object Tracking
http://www.cisco.com/en/US/products/sw/iosswrel/ps5413/products_feature_guide09186a00801d862d.html
Hope this help a bit,
if it does please rate this post.
vlad
06-22-2006 06:47 AM
Thank you, very much.
That's, what i've searched / needed.
I didn't know that Object Tracking even exists.
Greetings from Hamburg
