Loss of management
I keep losing connectivity to the management IP address on 2950 switches, although all other VLANs continue to work through it.
When I plug in a console connection, loads of buffered messages are output (just port up/down messages), and then IP starts working again.
This is happening on lots (but not all) of switches in lots of different locations.
Is anyone else aware of such a bug?
Re: Loss of management
It would be useful if you could post your switch configuration and also the syslog messages you see on the console .
Naryan
I do remember a bug offlate having same kinda behaviour which gets resolved with an ios upgrade.
It will be helpful if you can post out your current ios code which can be used to find out the match for the affected ios code.
regds
184
