You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Lost Serial interface on 7206
I removed a subinterface from a serial interface on my 7206VXR, 12.1(1)E5. Now the whole serial interface is gone. I tried reinstalling the controller. It takes the commands but after a write mem, it does not show up, nor does the serial interface. Ant ideas?
M
  • Other Network Infrastructure Subjects
Re: Lost Serial interface on 7206
Was it an actual serial port ?
the reason I ask this is that it may be an E1 controller card which is associated with a logical seral port.
If so then under the Controller config you will need to associate your timeslots with a channel group, e.g.
Controller E1 3/0
channel-group 0 timeslots 1-31
I would now have Serial 3/0:0
Hope that helps
John
Bronze
Mitchel,
Do you see the port adapter in the output of a 'show diag'?
-Zach
Have you tried a reload?
Well it is running in an environment were this is not desirable. The strange thing is when I came to work the next morning it was there. Very strange.
88
