low on memory, try again later error
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
hello, i work for an isp and we have recently been experiencing some major problem with one of our 2600 routers. After a certain period of time the router runs out of memory. we upgraded the ios and installed more memory as well as access-list for the recent virus'. here is a copy of the show memory processes command
router#show processes memory
Total: 42417564, Used: 14275692, Free: 28141872
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 143104 10892 2429864 0 0 *Init*
0 0 176 19920 176 0 0 *Sched*
0 0 7179888 2624756 68 163260 0 *Dead*
1 0 0 0 6884 0 0 Chunk Manager
2 0 188 188 3884 0 0 Load Meter
3 66 2900 940 15320 0 0 Virtual Exec
4 0 0 0 6884 0 0 Check heaps
5 0 88996 0 69640 21320 0 Pool Manager
6 0 0 0 6884 0 0 AAA_SERVER_DEADT
7 0 188 188 6884 0 0 Timers
8 0 188 188 6884 0 0 Serial Backgroun
9 0 188 188 6884 0 0 AAA high-capacit
10 0 188 188 6884 0 0 Environmental mo
11 0 22604 2051832 29488 0 0 ARP Input
12 0 0 0 6884 0 0 HC Counter Timer
13 0 188 188 6884 0 0 DDR Timers
14 0 4796 1172 10508 0 0 Entity MIB API
15 0 0 0 6884 0 0 SERIAL A'detect
16 0 188 188 6884 0 0 GraphIt
17 0 188 188 12884 0 0 Dialer event
18 0 0 0 6884 0 0 Critical Bkgnd
19 0 124032 0 116264 0 0 Net Background
20 0 188 188 12884 0 0 Logger
21 0 188 188 6884 0 0 TTY Background
22 0 0 0 9884 0 0 Per-Second Jobs
23 0 188 188 6884 0 0 SM Monitor
24 0 0 0 6884 0 0 Net Input
25 0 188 188 6884 0 0 Compute load avg
26 0 1084 0 7648 260 0 Per-minute Jobs
27 0 0 0 6884 0 0 Service-module a
28 0 188 188 6884 0 0 AAA Server
29 0 0 0 6884 0 0 AAA ACCT Proc
30 0 0 0 6884 0 0 ACCT Periodic Pr
31 0 188 188 6884 0 0 AAA Dictionary R
32 0 13415828 0 10849960 9360 0 IP Input
33 0 0 0 6884 0 0 ICMP event handl
34 0 12712 3060 16816 0 0 CDP Protocol
35 0 376 376 12884 0 0 PPP Hooks
36 0 0 0 6884 0 0 X.25 Encaps Mana
37 0 0 0 12884 0 0 TCP Timer
38 0 14384 0 14384 0 0 TCP Protocols
39 0 0 0 6884 0 0 Socket Timers
40 0 1868 0 11752 0 0 HTTP CORE
41 0 648 404 13128 0 0 PPP IP Route
42 0 188 188 12884 0 0 PPP IPCP
43 0 76 0 9960 0 0 IP Background
44 0 152 0 10036 0 0 IP RIB Update
45 0 188 188 6884 0 0 Adj Manager
46 0 0 0 6884 0 0 Asy FS Helper
47 0 0 0 6884 0 0 RARP Input
48 0 29824 188 22740 0 0 DHCPD Receive
49 0 0 173524 6884 0 0 IP Cache Ager
50 0 0 0 24884 0 0 COPS
51 0 188 188 6884 0 0 PPP Bind
52 0 0 0 6884 0 0 PAD InCall
53 0 188 188 12884 0 0 X.25 Background
54 0 188 188 6884 0 0 LOCAL AAA
55 0 188 188 6884 0 0 ENABLE AAA
56 0 188 188 6884 0 0 LINE AAA
57 0 2056 188 8752 0 0 TPLUS
59 0 188 188 6884 0 0 CRM_CALL_UPDATE_
60 0 188 188 6884 0 0 AAA SEND STOP EV
61 0 0 0 6884 0 0 Syslog Traps
62 0 1868 0 8752 0 0 SAA Event Proces
63 0 188 188 12900 0 0 HyBridge Input
63 0 188 188 12900 0 0 HyBridge Input P
64 0 376 188 7088 0 0 Tbridge Monitor
65 0 340 188 7052 0 0 Spanning Tree
66 0 188 188 12884 0 0 PPP manager
67 0 95860 712 108032 0 0 PPP Events
68 0 212 212 6884 0 0 Multilink PPP
69 0 188 188 6884 0 0 Multilink event
70 0 0 0 6884 0 0 DHCPD Timer
71 0 188 0 7084 0 0 DHCPD Database
14184728 Total
I blocked ports 69, 135, 445 and 593 for the virus. any other suggestions on what could be doing this. here is also a copy of the show version and running config. any suggestions would be greatly appreciated.
thanks
mike
IOS (tm) C2600 Software (C2600-I-M), Version 12.3(1a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 06-Jun-03 22:07 by dchih
Image text-base: 0x80008098, data-base: 0x80C90180
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
router uptime is 21 minutes
System returned to ROM by reload
System image file is "flash:c2600-i-mz.123-1a.bin"
cisco 2620 (MPC860) processor (revision 0x600) with 61440K/4096K bytes of memory
Processor board ID JAD052109ZD (703326654)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Building configuration...
Current configuration : 1036 bytes
version 12.3
service timestamps debug uptime
service timestamps log uptime
hostname router
enable secret 5 xxxxxxxxxxxxxxx
enable password xxxxxxxxxxxx
ip subnet-zero
interface FastEthernet0/0
description to office ethernet
ip address x.x.254.2 255.255.255.0
ip access-group 101 in
ip access-group 101 out
speed auto
full-duplex
bridge-group 1
interface Serial0/0
description to St. Gen
bandwidth 1536
ip unnumbered FastEthernet0/0
encapsulation ppp
no ip mroute-cache
no fair-queue
bridge-group 1
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip route x.x.254.0 255.255.255.0 Serial0/0
ip route x.x.138.0 255.255.255.0 x.x.254.1
ip route x.x.138.0 255.255.255.0 FastEthernet0/0
ip route x.x.138.0 255.255.255.0 x.x.138.1
bridge 1 protocol ieee
line con 0
password xxxxxxxxxx
login
transport preferred none
line aux 0
line vty 0 4
login
end
1 REPLY
Re: low on memory, try again later error
We have the same problem on a 3660.
Did you block icmp echo and echo-replies too?
290
