Community Member
mac-addresses,port speed of 2948G switch..info needed urgent
Can you please tell me what are the physical
addresses or mac-addresses for the 50 ports of switch 2948G?i need to
populate values in RFC1213-MIB and IF-MIB to simulate the agent.i got
this info
Compare:
c2948-dc> (enable) show module
Mod Slot Ports Module-Type Model Sub
Status
1 1 0 Switching Supervisor WS-X2948 no ok
2 1 50 10/100/1000 Ethernet WS-C2948G no ok
Mod Module-Name Serial-Num
1 JAB034607C5
2 JAB034607C5
Mod MAC-Address(es) Hw Fw Sw
1 00-30-40-6f-a8-00 to 00-30-40-6f-ab-ff 2.0 6.1(4) 7.4(2)
2 00-30-40-6f-ab-9e to 00-30-40-6f-ab-fd 2.0
Can you infer the ifPhysicalAddresses for the 50 ports.please reply
me.and
from IF_MIB,
ifMtu = The size of the largest packet which can be sent/received on
the interface, specified in octets. For interfaces that are used for
transmitting network datagrams, this is the size of the largest
network datagram that can be sent on the interface
ifSpeed = An estimate of the interface's current bandwidth in bits per
second. For interfaces which do not vary in bandwidth or for those
where no accurate estimation can be made, this object should contain
the nominal bandwidth.
2948G has 48 ports of 10/100Mbps and 2 ports of gigaspeed.is
ifSpeed=portSpeed.
if so,can i set 48 ports to either 10Mbps or 100Mbps??
and what is the value of ifMtu in this case?
Since i need replies asap,any help is really appreciated.
BestRegards
E.L.R.Arunkumar
www.adventnet.com
1 REPLY
Gold
Re: mac-addresses,port speed of 2948G switch..info needed urgent
mtu for ethernet is 1500 bytes
ifSpeed = port speed.
the mac addresses show a range of 1024 possible on the supervisor and 95 on the 10/100/1000 card.
I would hesitate to infer anything from that.
99
