Webcast-Catalyst9k
maintenance
Dear all,
We are doing maintenance for our networks which contents the following
Cisco 3550 series switches
Cisco 2900 series switches
Cisco 2950 series switches
Cisco LRE switches 2950 series
Cisco router 1811
Cisco router 1750
Cisco router 2600
Now, I would like to know the commands which are use for the above cited devices.
Example: - show environment
show post
show region
Thanks in advance.
Khan
Hall of Fame Super Bronze
Re: maintenance
The most comprehensive command is:
show tech-support
Make sure to enable capture on whatever terminal application you are using, the output is quite large.
Please rate helpful posts.
Re: maintenance
hi,
As per your query here are some links that you can use for the following devices to check the show commands supportedand their use:
Cisco 3550 series switches: http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12225see/cr/cli2.htm
Cisco 2900 series switches: http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/29_35wc6/cli/clicmds.htm
Cisco 2950 series switches: http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12122ea5/2950cr/cli2.htm
Cisco LRE switches 2950 series : http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12122ea5/2950cr/cli2.htm
Hope this helps !!
Param
300
