You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Making a Catalyst 6500 an ATM switch
I know a 6500 can act as a ATM switch, but what I want to know is: Is it going to route or is it going to switch? It's very important for me to know, because of the fact we absolutely don't want ATM routing. What I want is a redundant ATM ring of 3 locations with behind each location an IP network. Because if you want a redundant connection, I think you need to route and I don't want that.
  • Other Network Infrastructure Subjects
1 REPLY
Silver
Re: Making a Catalyst 6500 an ATM switch
The 6500 cannot act as an ATM switch (route ATM cells from ingress to egress). It is only a UNI and never and NNI device. The 6500 series is a termination point for ATM connections only. I don't quite understand your 3 ring question, but assuming you mean you have 3 6500's connected to each other in a ring, with point to point ATM connections between each, this would work just fine.
Hope this helps,
Don
99
